Only 1 Milling Limit Line
Well I guess I'm the only person still using criteria files since I'm the first to post here, lol.
I'm coming across an issue where the cross sections aren't plotting due to only finding 1 Milling Limit Line. However, there are two lines on each side of the pavement, they both have the exact same adhocs, are in the same file, are not an unsupported line type (i.e. b-spline curve) etc. I have re-created xs runs to see if maybe starting a fresh one would solve the problem but it didn't.
I just ran M&R cross sections on another chain in the same project and they worked fine. But now its not.
Any help would be greatly appreciated. A few things I haven't tried are re-creating the file itself (which I will try now) or re-creating the design file.
Lizette
  • I know the criteria is going through some major rewrites and the milling critria is among the code being addressed.  Stay tuned. We will work out a solution to the issue you are experiencing.
  • Hey Brad thanks for the response. I actually (after much trial and error) got them to run. This particular road is a two lane UN-divided section. I had a Median line with an adhoc of 7 running through the center line thinking that it needed this. I realize now it shouldn't have had any median line and as soon as I deleted it the cross sections came in perfectly. It's a match existing section so nothing too complicated.
    But thanks again for your help, and I guess if someone else comes across this issue now they now how to fix it, lol.
Reply
