Is there a way to add a dtm or tin file from the surveyor to existing x-sections to get the earthwork quantities?
You can use the Draw Cross Section tool to draw the new surveyed ground into preexisting cross sections as either a DTM or TIN. Getting the earthwork quantities is another matter. The Earthwork tool is very particular about the elements connecting exactly. Potentially, there could be a lot of hand work to make all the elements connect. I do not know of any easy way to get earthwork quantities. I will continue to look for a solution. You can give me a call to discuss.
Answer Verified By: whitworth.bird@yahoo.com
