Storm Tab Report
I'm having a problem with verifying the results of the Storm Tab Report. The Hydraulic Grade Line slope does not match a calculated slope using the Hydraulic Gradient Fall and the Length of the pipe. I've turned off minor losses by "checking" the 'Disable All Junction Loss Computations' in my preferences. But it seems as if it is computing exit losses. In my link options, I have 'Hydraulic Gradeline Basis' set to 'Equal to Hydraulic Gradeline'.
Is there anything else in my preferences that would affect the Hydrualic Grade Slope calculation?
Also, is there a way to export my network to ASAD?
