Hello guys:
I am having issues when trying to analyze networks in Geopak Drainage. I get the following error when I try to analyze networks: Error Computing Hydraulics for Network (network Name), followed by:
Errors Preclude ComputationsErrors Preclude ComputationsError Computing Inlets Calculations for NetworkError in Inlet By Pass Designations - Loop DetectedInlet Tñ( - Error Performing Inlet ComputationsDrainage Area Tñ( Not Found
Any Ideas on what Tñ is? I do not have any nodes or areas named Tñ in my networks. When I check on my navigator, the Inlet tab is populated by a number of Tñs, see attached image. Any ideas on what's causing this issue and how it could be solved? I never had this problem with SS2. I am currently running SS4 Version (01.00.00), Microstation V8i (SELECTseries 3) Version 08.11.07.714, and Geopak V8i (SELECTseries 4) Version 08.11.09.845.
Thanks!
Did you find a solution? I get the same error.
Try this: If you're running the FDOTSS4 workspace, close FDOTSS4 and go to the FDOTSS4 folder on your desktop. Run "Workspace Doctor" with all of the options enabled.
Restart FDOTSS4 and see if that resolves the issue.
If that did not work, close FDOTSS4 and navigate to C:\Program Files (x86)\Bentley\PowerGEOPAK V8i (SELECTSeries 4)\PowerGEOPAK\Civil\bin (if you're running Microstation/GEOPAK, the path is similar but I believe it's GEOPAK\BIN)
Locate GEOPAKCOM.EXE, right click on it and select "Run As Administrator..."
If you get no errors, restart FDOTSS4 and see if the issue is resolved. If you get any errors when running GEOPAKCOM.EXE, let me know and we'll further troubleshoot. If the problem otherwise persists, I'll log a ticket and see if we can get our current drainage expert on it.
Matt SextonCADD Applications Support CoordinatorFlorida Department of TransportationEngineering/CADD Systems Office850-414-4840matt.sexton@dot.state.fl.us
Thanks Matt, that did not resolve it...but I did lose all my custom settings
I'm guessing that the gdf file is corrupt, and my morning has been wasted...
