Error Opening Drainage Project
I am getting an error message when I try to open a Geopak Drainage project.
Just seems to be this particular project as I was able to open Geopak Drainage file in another project.
Anyone seen this and know how to fix it?
  • Also, here is my Geopak Drainage file in case that will help someone figure this out. I also tried a different geopak drainage file in the same project and that one worked just fine as well. Seems like there is something corrupted in this one potentially.
    https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/343104/WesternWay.gdf
    Zachary Billings, P.E.
    Senior Roadway Engineer (Licensed in FL and MI)
    CONSOR Engineers, LLC
    System Info:
    Windows 11 | Intel Core i7-13700k | Nvidia RTX 4090 FE | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
    ORD Version 10.12.02.004 | FDOT Connect Version 10.12.01.00
    YouTube Page for ORD: https://tinyurl.com/BillingsCADD
  • I just got a file restore of the file. The file I posted above is 9kb, which seems too small. The restored file is 43kb. As soon as I try to load, I get the above error message, the drainage lock file shows up, and the gdf reduces back to 9kb. Going to try to get an older version of the file and see if I can get that to work.
    System Info:
