I’m having trouble getting the proposed Drainage Structure Cross Sections to run in SS4. I ran the existing and proposed cross sections through the corridor modeler cross sections and then used the GEOPAK proposed roadway cross sections to run the Drainage Sections. Attached is the LOG file for the run if it helps.
