I am running into the following issue when attempting to analyze a network:
Errors Preclude ComputationsErrors Preclude ComputationsError Computing Inlets Calculations for NetworkError in Inlet By Pass Designations - Loop Detected
I have attempted to identify any solutions to the problem to no avail.
Moreover, the node editor and navigator show node "O‡–˜" to be present, despite the fact that I did not manually input any such nodes or areas into my network.
Restoring the .gdf file to a previous version before the error was encountered did not ameliorate the problem.
I am running Microstation SS4 v8.11.9.832
Any help would be greatly appreciated,
Rinor.
Hello James,
Thanks for the reply! Any suggestions on how to fix the corrupt file?
-Rinor
