I receiving the attached error when running the Drainage Tabulation tool from the menu bar. I have a drainage project open and the GEOPAK gpk path as well as working directory path are pointed to the drainage folder. The GPK and GDF files are in the drainage folder. The GDF file opens fine and the network can be analyzed OK.
Using PowerGEOPAK 08.11.09.878 and FDOT SS4 MR9.
Sean Keene
In the VBA editor go to Tools and References. You will notice a Missing reference. Uncheck it and save the VBA. you will need to restart MicroStation and the vba but it should work fine.
Thank you sir, works just fine now.
I spoke too soon. The Drainage Tabulations 2.2.0 dialog opens but when I select the drainage network from the Report Network pulldown I receive runtime error.
Bob, any thoughts on the next error?
This issue is keeping a few projects from moving forward. The PM from our side is hoping to get this issue resolved as soon as possible. Is there someone else I can contact?
