I receiving the attached error when running the Drainage Tabulation tool from the menu bar. I have a drainage project open and the GEOPAK gpk path as well as working directory path are pointed to the drainage folder. The GPK and GDF files are in the drainage folder. The GDF file opens fine and the network can be analyzed OK.
Using PowerGEOPAK 08.11.09.878 and FDOT SS4 MR9.
Sean Keene
Give me a call, @850-414-4778 or drop me a line at Robert.thorburn@dot.state.fl.us
Thanks again for your help Bob, the solution for adding the 64 bit Office call in the DrainTab.mvba has fixed the issue.
you're welcome.
I am looking for this solution now. Do you remeber what reference to the VBA needed to be attached? Thanks.
We had some issues with this VBA previously and this is the solution we came up with.
Zachary Billings, P.E.
Senior Roadway Engineer (Licensed in FL and MI)
CONSOR Engineers, LLC
System Info:
Windows 10 | Intel Core i7-9700k | Nvidia RTX 3080 FTW3 Ultra | 32 GB of RAM | 2 TB Samsung 970 EVO Plus NVME
Power GEOPAK V8i Select Series 10 Version 08.11.09.918 | FDOT SS10 Version 01.04.01
ORD Version 10.10.21.04 | FDOT Connect Version 10.10.01.00
YouTube Page for ORD: https://www.youtube.com/channel/UC3S-94f7_yUJ-GMhMYPhInA
