I am trying to display drainage structures in the profiles using the Drainage Plans workflow in the FDOT Plans Development. When I click the icon to do so, I get an error: "VBA interface error: unable to run macro - 0x80040552"
I read some other forum solutions that said a prerequisite executable was needed, but that didn't do the trick. Using Power Geopak SS10 08.11.09.918
The VBA interface error in Select Series 10 has a number of potential causes. The primary cause we discovered is that the Bentley Controls OCX file is not being registered during installation. You can unregister and re-register this file to try to resolve the issue. Try this:
Regsvr32 /u "C:\Program Files (x86)\Common Files\Bentley Shared\GEOPAK\08.11.09\BentleyControls.ocx"
Regsvr32 "C:\Program Files (x86)\Common Files\Bentley Shared\GEOPAK\08.11.09\BentleyControls.ocx"
Matt SextonCADD Applications Support CoordinatorFlorida Department of TransportationEngineering/CADD Systems Office850-414-4840matt.sexton@dot.state.fl.us
Answer Verified By: Kevin Deckers
This seems to have done the trick! No error this time around. Thank you for your quick reply and help!
