While running FDOTSS2 Drainage Structures Cross Section the AH & BK pipes are drawn lower than the pipes Invert data and lower than the bottom of structure. When running the same data with FDOT2010 the pipes are drawn correctly. What will cause the pipes to be drawn incorrect in FDOT SS2?
Power Geopak V8i-Version 08.11.07.615
FDOT2010.04.00
FDOTSS2 Version: 01.01.00
The origin for the pipe cell was inadvertently moved during the transition to be compliant with Annotation Scale. Please look under the Files tab to find a replacement file for the xsections.cel file.
Answer Verified By: beconaze
