Median Barrier Inlets
Hello everyone,
I have some question regarding the placement of Median Barrier Inlets in Geopak Drainage. Should I have two structures in the same location one to take the area from the left and another to take the area from the right? Or should I just have one structure and assign the sum of left and right areas to it?
Thanking you in advance!
  • You should use the InltMedBarrD Library item that is suitable for the situation. This should have the flow from both the left and right sides attributed to it. I think you will have to combine the two drainage areas into one so that you can do this (I may be wrong on that, if anyone else has info). I have included a screen shot of the items to look for in the Node dialog.
