Where is the setting for Print Organizer to print the job to a single .pdf file? There should be a check box at the bottom of the print dialog to open file after printing, but now I'm seeing use master design file directory for print destination and all the sheets print as separate .pdf files.
Answer Verified By: Polk County Draftsman
