Alignment Annotation Issue with Curve Data
An issue was recently discovered when annotating an alignment in FDOTConnect10.11. On an annotated alignment the curve data is incorrect on curves to the left. Specificaly the radius populates the same as the length. See screen shot. Curves to the right show the correct data.
To resolve the issue, Overwrite the .dgnlib located here: C:\FDOTConnect10.11\Organization-Civil\FDOT\Dgnlib\Feature Definitions
 Re-annotate your alignment and that should get you the correct value in the Curve Data Label.
See attached updated DGNLIB
FDOT_Text Favorites_Text Styles_Dimension Styles.dgnlib
