Sometimes I need to plot rasters in color and I use this plot config file with the FDOT.tbl pen table. Is there a way to force all the vector elements to plot in color 0 while still allowing the rasters to plot in color?
Hi Pat,
You can customize a Pen Table and add an entry that will accomplish this.
From the Print dialog attach the FDOT pen table and the select Save As to save it as a new name in you project directory.
Add a new section ( Edit > Add New Section Below) and define the Selection criteria to select all Types but raster (leave other selection criteria blank).
Then set the Output Action to change the color to an RGB value of 0,0,0. Save the pen table and give it a try.
Thanks Jimmie, works like a charm. Now, is there a line I can add to my pen table to automatically turn off data fields when plotting?
Patrick, DraftsmanImperial Polk County, FL
Power GEOPAK V8i (SELECTseries 4)Version 08.11.09.878Cadpilot UI cadpilot.ui.01.07.00 - build.2013.01.22.1042
In the plot dialog, click on Settings>Print Attributes then unchech Data Fields.
