I can see how to change the pen table once I have a .pset file, but how do you change the plot configuration file?
The PLTCFG file associated is a property of Print Organizer not the Print Definition. Print Organizer will print to one device at a time. To set the output select File > Printer Setup from the Print Organizer menu.
On the Printer Setup dialog you have the option to select the PLTCFG file.
Answer Verified By: Traffic Draftsman
Is there a way to set this to default to another print driver, so that I don't have to keep setting it. I'm running FDOTSS4, and it is still defaulting to "C:\FDOT2010\RESOURCES\plot\hp5000.pltcfg".
I want it to default to "C:\FDOTSS4\RESOURCES\plot\FDOTPDF.pltcfg".
Thank you.
Rusty Snider
