Can someone tell me why this is happening? I'm using some 8.5x11 borders with a shape set on PlotBorder_dp with 5 sheets in the file, but when I try to plot, I'm getting the results shown below. I'm using the standard FDOT.tbl with a custom plot driver based on the FDOTPDF.pltcfg. I attached the files I am using.
I think you just need to delete you printer definition (or create a new pset) so it can rescan for borders.You can then reset the paper size if 8 1/2 x 11 in not the default paper size.
This is what I got after recreating the print definitions and then resetting the paper size in Print Organizer.
Give it a try and if that doesn't work give me a call and we will do a GoToMeeting to see what's going on.
Answer Verified By: Traffic Draftsman
Thank you.
Patrick Serpas, DraftsmanImperial Polk County, FL
Power GEOPAK V8i (SS 2) v.08.11.07.615Descartes V8i v. 08.11.09.432GuidSIGN v. 6.0.0Cadpilot UI 01.07.00 - build 2013.01.22.1042
Windows 7, Intel i5-2400 CPU @ 3.10 GHz, 4 GB RAM
