In Microstation, i have turned off several levels from a referenced file that I don't need to see. When I print that using my print organizer print set, the levels that are supposed to be off are printing. I can also see them in the preview of the properties window for that file.
This seems to be something new since the SS2 update because I don't recall ever having this issue before.
Can anyone confirm this and help me out?
In solving another issue, I think I solved this problem as well.
The other issue is here: communities.bentley.com/.../91516.aspx
Jimmie was able to provide me with a fixed FDOTPDF.pltcfg which can be downloaded from that thread. That seems to have also fixed levels printing that were off in the file.
Thanks again Jimmie
Zachary Billings, P.E.
Senior Roadway Engineer (Licensed in FL and MI)
CONSOR Engineers, LLC
System Info:
Windows 11 | Intel Core i7-13700k | Nvidia RTX 4090 FE | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
ORD Version 10.12.02.004 | FDOT Connect Version 10.12.01.00
YouTube Page for ORD: https://tinyurl.com/BillingsCADD
I was testing this today and was unable to reproduce the problem. If I turn off levels and save settings in the DGN file it turned them off in the prints as well.
