I have been receiving this warning from Print Organizer for quite some time. The warning message is " 'Plotborder_dp' is not a valid level for file '...' and occurs with each file added to the print set. I have to hit ok in order for the program to add the file and move on to the next drawing. This is a pain when dealing with multiple files. Is there a way to stop this or deactivate the warning?
What version of MicroStation and the FDOT software are you using?
I would run into this error when I set up a batch print using manually specified options. Instead I attach the "print style name" of FDOT PDF.
If you I had to manually specify options, I would place my stapler on the enter key to accept all of the notifications.
MicroStation 08.11.07.443
FDOT 2010.04.00
By the way, the stapler on the enter key trick worked great! Shouldn't have to do that though...
Haha, agreed. :)
i can not stand print organizer, i still use batch print.
