Changes to Sheet Navigator and Pset's
I've noticed that since the new release, there is a new column in Sheet Navigator called Print Order. Which is different from my sheet numbers. When generating a .pset from Navigator it seems to put all the sheets in the print order instead of by sheet number like I want it. Also, after fixing the order in my pset it says its unable to open view group Default. I've never seen this error before. Any help would be greatly appreciated.
FDOTSS2 MR1
Microsation v. 08.11.09.459
