I am unable to run the Summary of Drainage Structures 'Drainage VBA' with the new SS3 Site Menu. I receive an error stating "VBA interface error: unable to macro - 0x80040552". Is this an issue that is easily fixed? I am currently using Office 2010 but haven't had issues with the Data Link Manager. Thank you.
Yes. To fix this error, close out of FDOT SS3 and in the folder C:\Program Files (x86)\Bentley\GEOPAK V8i (SELECTSeries 3)\GEOPAK\bin\ (if you are running PowerGeopak the path is a little different) look for the file geopakcom.exe. Right-click on that file and click Run as administrator. Open FDOT SS3 again and try the Drainage VBAs.
Christi
I am running Office 2010.
