I have a user getting the following errors:
MDL Loader: Unable to load library (DLL or MDL shared library) kernel32Dll Loader: unable to find kernel32.dll
Linked Data Manager: (0) links found in 00:00:000Linked Data Manager: Scanning...
Replaced missing TrueType font [SketchFlow Print] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Segoe Marker] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Segoe Condensed] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Nina] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [LuzSans-Book] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Buxton Sketch] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Trajan Pro] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Tekton Pro Ext] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Stencil Std] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Rosewood Std Regular] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Prestige Elite Std] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Poplar Std] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Orator Std] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [OCR A Std] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Nueva Std Cond] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Myriad Pro] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Minion Pro SmBd] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Mesquite Std] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Lithos Pro Regular] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Letter Gothic Std] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Kozuka Mincho Pr6N B] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.Replaced missing TrueType font [Kozuka Gothic Pro R] with [Arial]. Some text may not display correctly. Make sure that the True Type Font is installed in the system. Fallback fonts are specified in the Font Configuration File.
The primary error is the first kernel32 error. Not sure if the font errors are related. Other users also get font errors, but a different set of fonts. Font list is abridged for brevity.
PowerGEOPAK 9.722 - SS3 Workstation 01.01.01
Kernel32 error occurs in all files for one particular user. Other users don't aren't getting the error. Occurs for all user profiles on that particular pc. Occurs on a blank test file on the C: drive. Does not occur in just PowerGEOPAK w/o the bar menu. Occurs initially on file open before any user activity, then will routinely occur when selecting Set Plot Scale on bar menu. Set Plot Scale dialog windows does not display. Has not been observed to occur for any other bar menu choice.
Did repair/install of SS3 and pgpk which produced no affect.
Any help, clues, resolution, etc. would be appreciated.
Mike Champion, Orlando
