I am trying to create a curve data table for my project and it keeps giving me an error. I get the VBA error below. Also, when clicking the question mark box for the help in the bar menu, it opens a blank window.
Close out of Microstation Navigate to the PowerGEOPAK/Microstation-GEOPAK Suite install directory: C:\Program Files (x86)\Bentley\PowerGEOPAK V8i \PowerGEOPAK\Civil\bin\ or C:\Program Files (x86)\Bentley\GEOPAK \v8.11\bin\ Locate the file geopakcom.exe. Right-click on the file Click Run as administrator. Let me know if this works.
Important Note:
FYI - running Geopakcom.exe...
This is something you have to do with GEOPAK dual version platforms. It does fix the version of PowerGeopak/MicroStation that it's run from, but it can break other versions. (Last run takes precedence). This could affect several other mvbas.
If you have dual version platforms installed you may have to perform this procedure on other version platforms (ie. SS2, SS3 and eventually, SS4 (due out sometime this Summer)) to get MVBAs to run in the other version platforms. Last run takes precedence).
Zachary Billings, P.E.
Senior Roadway Engineer (Licensed in FL and MI)
CONSOR Engineers, LLC
System Info:
Windows 11 | Intel Core i7-13700k | Nvidia RTX 4090 FE | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
ORD Version 10.12.02.004 | FDOT Connect Version 10.12.01.00
YouTube Page for ORD: https://tinyurl.com/BillingsCADD
Vern
