I have been unsuccessfully trying to create a print set using the FDOT toolbar. I have reinstalled it and problem persist. Has anyone encounter this issue and how did you solve it?
The version of Microstation you specify is for FDOT2010. FDOTSS3 should not be installed on this platform. I think this is the problem as we have indications that the message you are receiving occurs with out-of-date or missed match platforms.
I recommend upgrading to our latest version (FDOTSS4):
http://www.dot.state.fl.us/ecso/main/Version/CurrentVersions.shtm
However, if that's not possible at least update to the following versions:
http://www.dot.state.fl.us/ecso/main/Version/PreviousVersions.shtm
Answer Verified By: Leo Rodriguez
