SheetInfo_Settings not working
I have been following this guide here:
I have always followed that guide and had no issues excluding folders from my Sheet Navigator. Now, for some reason, even though I have done everything correct as far as I can tell, the folders that I want to exclude keep getting Indexed.
I have tried creating a brand new xml and copying my info into the new file. Then i leave Microstation and get back in and run Sheet Navigator and it is still indexing the folders I dont want.
I have attached my SheetInfo_Settings.xml if anyone wants to take a look and let me know what I am doing wrong.
<?xml version="1.0" encoding="utf-8"?>
<SheetInfoProjectSettings>
  <OverrideSettings>
    <Cells>
      <EngineeringRecordCells>
      </EngineeringRecordCells>
    </Cells>
    <SearchCriteria>
      <SheetNumberReferences>
      </SheetNumberReferences>
      <SheetBoundaries>
      </SheetBoundaries>
      <SheetTypes>
        <SheetType name="02-BUILDING CONSTRUCTION PLANS">
        </SheetType>
        <SheetType name="03-LANDSCAPE PLANS">
        </SheetType>
        <SheetType name="04-LIGHTING PLANS">
        </SheetType>
        <SheetType name="05-ROADWAY PLANS">
        </SheetType>
        <SheetType name="06-SIGNALIZATION PLANS">
        </SheetType>
        <SheetType name="07-SIGNING AND PAVEMENT MARKING PLANS">
        </SheetType>
        <SheetType name="08-BRIDGE HYDRAULIC PLANS">
        </SheetType>
        <SheetType name="09-ROADWAY SOILS SURVEY">
        </SheetType>
        <SheetType name="10-RIGHT OF WAY MAPS">
        </SheetType>
      </SheetTypes>
      <SheetDataFields>
        <SheetDataField name="EngineeringRecord">
        </SheetDataField>
        <SheetDataField name="SheetNumber">
        </SheetDataField>
        <SheetDataField name="SheetDescription">
        </SheetDataField>
        <SheetDataField name="ProjectDescription">
        </SheetDataField>
        <SheetDataField name="RoadNumber">
        </SheetDataField>
        <SheetDataField name="FPI">
        </SheetDataField>
        <SheetDataField name="County">
        </SheetDataField>
      </SheetDataFields>
    </SearchCriteria>
    <IndexingIgnoreFiles>
    	<File name="*.pdf" />
    	<File name="*.uns" />
    	<File name="*.cel" />
    	<File name="*.old" />
    	<File name="*.bak" />
    	<File name="BDPLRD*.dgn" />
    	<File name="BDPPRD*.dgn" />
    	<File name="BDPLLT*.dgn" />
    	<File name="BDPLIT*.dgn" />
    	<File name="BDPLLD*.dgn" />
    	<File name="BDBRRD*.dgn" />
    	<File name="BDDMRD*.dgn" />
    	<File name="BDPRRD*.dgn" />
    	<File name="BDXSRD*.dgn" />
    	<File name="BDPLSG*.dgn" />
    	<File name="BDPLSP*.dgn" />
    	<File name="BDXSSP*.dgn" />
    	<File name="BDXSIT*.dgn" />
    	<File name="BDPLUW*.dgn" />
    	<File name="TYPDAT*.dgn" />
    	<File name="TYPDRD*.dgn" />
    	<File name="GKLNRD*.dgn" />
    	<File name="Topo*.dgn" />
    	<File name="dsgn*.dgn" />
    	<File name="algn*.dgn" />
    	<File name="dspf*.dgn" />
    	<File name="plan_motif*.dgn" />
    	<File name="profile_motif*.dgn" />
    	<File name="CM_*.dgn" />
    	<File name="clip*.dgn" />
    	<File name="B*STRBORDER*.DGN" />
    	<File name="STRBORDER*.DGN" />
    	<File name="QTDSRD*.DGN" />
    	<File name="GDTM*.DGN" />
    	<File name="DTM*.DGN" />
    	<File name="UTSVUW*.DGN" />
    	<File name="MTPL*.dgn" />
    	<File name="MTPR*.dgn" />
    </IndexingIgnoreFiles>
    <IndexingIgnoreFolders>
    </IndexingIgnoreFolders>
  </OverrideSettings>
  <MergeSettings>
    <Cells>
    </Cells>
    <SearchCriteria>
      <SheetBoundaries>
      </SheetBoundaries>
      <SheetTypes>
        </SheetType>
        </SheetType>
        </SheetType>
        </SheetType>
        </SheetType>
        </SheetType>
        </SheetType>
        </SheetType>
        </SheetType>
      </SheetTypes>
      <SheetDataFields>
        </SheetDataField>
        </SheetDataField>
        </SheetDataField>
        </SheetDataField>
        </SheetDataField>
        </SheetDataField>
        </SheetDataField>
      </SheetDataFields>
    </SearchCriteria>
	<Folder name="struct" />
	<Folder name="survey" />
	<Folder name="Floodplain_Analysis" />
	<Folder name="Dredge&Fill" />
	<Folder name="RW_Exhibits" />
	<Folder name="DTM" />
	<Folder name="LA_RW_Fencing" />
  </MergeSettings>
</SheetInfoProjectSettings>
