When I click the reference-raster cleanup utility I get a error box stating "Compile error in hidden module: isMissing" I am using FDOTSS4 MR3 bar menu
Chad,
I found a ticket regarding this from a number of years ago. Try this:
Copy the MSCOMCTL.OCX file from c:\Windows\System32\ to C:\Windows\SysWOW64\
Matt SextonCADD Applications Support CoordinatorFlorida Department of TransportationEngineering/CADD Systems Office850-414-4840matt.sexton@dot.state.fl.us
does it take a reboot as I did what you said and got out of CADD and got back in and no difference
Chad, give me a call and we can troubleshoot this via GoToMeeting. I'm available until 5PM today and will be in the office at 8AM tomorrow.
I spoke with Bob about the relative path, full path and filename-only formatting for reference files that we encountered after fixing the missing VBA reference in the cleanup tool. The tool will only remove full path, converting it to filename-only; it apparently will not remove relative path to convert to filename-only formatting. That being said, in our workflow, for all functional purposes, the relative path formatting should work just fine for FDOT projects. If you run into any problems with the relative paths, please let me know and I'll be glad to assist.
