SS2 Cadpilot Menu does not display menu items when selected running on Windows 10 OS. Same as the issue with SS4. There was a fix provided for SS4. Is there a fix for SS2? We have several projects that have to stay in SS2 and need a work around if there is
yes Mitch there is a fix. This error was caused by the Windows Creator Update. There is an update on our website that will correct the SS4 version then you will need to copy the three files in C:\FDOTSS4\MENU\Program\ustn0811\ to the same folder in SS2. Call me if you have any problems
http://www.fdot.gov/cadd/downloads/software/FDOTSS4CaddSoftware.shtm
