Design Apps > Reference Files > Reference File Tools
I'm attempting to use this tool.... Design Apps > Reference Files > Reference File Tools
I'm trying to batch replace references but it doesn't work. It recognizes the files I would like to change and acts like it is loading and updating the files with the cadmanage batch window however when I open the files nothing has changed. The CM.Batch Process Summary Report says all files were SUCCESS. I can get it to work with processing current design file (one file at a time), which is also buggy. Sometimes it takes two attempts to get it to process the changes I've input.
Has anyone had this tool work successfully lately? Another user in the office mentioned that it hasn't worked for sometime now.
It would be useful to have this tool function properly since I have about 200+ files that I'm currently having to update individually.
Thank You,
Dan
