I'm using a county map downloaded from the FDOT website, using the name as it downloaded (co-pasco.dgn). QC Inspector returns an Invalid filename message. Has the file naming convention for County Maps changed?
Good morning Terri are you using this for a key sheet?
Yes I am.
We don't use the DGN files for Key sheets any longer, we use the PDF files. There is an instructional video on this process on line. I will look it up for you and post it here.
https://www.youtube.com/watch?v=Oz7-WATJEy4
Thank you Bob. I was going to use the pdf but the project crosses county lines and I couldn't see how to show both counties with the pdf (shapes blocked the other county). If we are not using dgns anymore, I'll try to figure out how to make the pdf work in this case.
What is your second county?
