I'm using a county map downloaded from the FDOT website, using the name as it downloaded (co-pasco.dgn). QC Inspector returns an Invalid filename message. Has the file naming convention for County Maps changed?
I showed an example from another project. The project with two counties is Union and Bradford. Besides having overlapping shapes, they also do not come in lined up. Another reason I went with the dgn is my last submittal was rejected for having pdf files in my Cadd Zip. It was a pdf of a Geopak alignment which I thought was okay. Since then I make sure there are no pdf files in the Cadd zip.
your Key sheet will pass compliance using a PDF. What is your other Count, Pasco and?
Sorry - mentioned in previous reply - Union and Bradford are the counties. Pasco was from another project which I was in when I created the example.
I went and spoke to the GIS group downstairs. Can you get me in the neighborhood of the project and I can get you a PDF.
Does this map help? It is a trail that runs near SR 100 from Palatka to Lake Butler. I attached both pdfs and clipped. Had to clip along New River. GIS group could probably put this together better than I can. Thanks!!
.PDF
