I have upgraded to FDOT SS10 and Office 2016. When accessing the Drainage Pattern VBA from the Drainage menu it produces a VBA Interface Error.
Any help is appreciated.
Mike
Mike,
This is likely caused by a DLL registration that was left out of Bentley's SS10 installation process. We have added a command to the FDOTSS10 installation to take care of this, but it is possible that the command might not have run. Try this to see if it resolves the issue:
Matt SextonCADD Applications Support CoordinatorFlorida Department of TransportationEngineering/CADD Systems Office850-414-4840matt.sexton@dot.state.fl.us
Matt,
Thank you, this resolved the issue.
