When trying to run the Sheet Navigator to build the Sheets list we are getting Error occurred. Index file wasn't created error.
The project path is: P:\2020\00417\C. Design\C. CAD\44334715201
We are able to run on another project so I know there is something off with this one, I did check permissions and all are the same.
Any insight would be appreciated.
Mike SteffyAmerican Structurepoint
It's like the spaces and dots in the path causing the issue.
Matt SextonCADD Applications Support CoordinatorFlorida Department of TransportationEngineering/CADD Systems Office850-414-4840matt.sexton@dot.state.fl.us
Thanks Matt. The other project path that it works on is: P:\2019\00393\D. Drawings\43667212201
I am having the project team look into the folder structure and naming as the possible issue.
