FDOT SS10 Linked Data Manager Error (Project Folder Not Found)
Hello.
I am unable to create excel link in LDM. It says "Project Folder Not Found". I am using SS10 and PW. Please help.
  • You can create a work around for this by creating a _meta_info folder in your local C: drive location where ProjectWise copies files to when checking out. I use this workaround for FDOT Connect ORD as well.
  • ProjectWise Explorer will not create the folder structure that LDM reads (among other FDOT tools). Apart from Nicholas' suggestion, you could also create a local Workset and export there, work outside of PW, then import back to PW when done.
    Eddie Giese, PE
    Production Manager | Senior Roadway Engineer
    Licensed in FL & PA
    ACEC FDOTConnect Instructor on behalf of FDOT
    Patel, Greene & Associates, LLC
    PowerGEOPAK V8i SS10 (08.11.09.918)
    OpenRoads Designer 2021 R2 (10.10.21.4)
    OpenRoads Designer 2020 R3 (10.9.0.91)
    ProjectWise Explorer CE 10.0.3.453
    LumenRT CE Update 14 (16.14.60.98)
    premier-scholar-badge road-designer-badge
