Creating structure table for FDOT Drainage structure sheets
Hi
I am creating Drainage structure sheets per FDM 916 and the FDM requires a "structures" table that includes all inlets as well as manholes. However in ORD drainage, there is no option for a combined manhole and inlet table, they are separated into a CB and MH data table.
How would i create this structure table, or do i have to manually combine it
Thank you, Ravi
FDOT Connect 10.12.00.00
