We are working on a project that is still utilizing ODOTcadd standards. When using the sheet manager, the info is exported to Excel and everything is filled out. When we try to read the file back into microstation using "Excel Input", we are getting the following error:
I have went back and re-watched the sheet manager video and we are following the process outlined. I'm not sure where our issue is. Any help would really be appreciated.
Brad
Make sure everyone is out of sheet files but the person running the sheet manager.
--EDITED--
this should not cause an error message.
-edited-
Steve below is right this causes the error
I don't use projectwise but this is the EXACT message I get when someone else is in another sheet and it cant number it. After said person gets out of the sheet files, it works as its supposed to. Not saying this is whats happening with the OP but this is what happens for me ALL the time. Even happened just yesterday. After she got out of sheet....voila. :)
thank you Steve, I will look into the code and see if something needs fixed in the code. because it is suppose to verify that. ill post back here
well my brain is stuck on CONNECT. i need to take back what i said about the sheet manager. all of that was for the connect version of sheet manager. ill edit my response to remove any confusion the odotcadd stuff is not integrated with ProjectWise.
