Special Characters in ODOTcadd font?
Where are the centerline, baseline, flowline, etc. characters in the ODOTcadd font?  The pipe, brackets, etc. appear to just be the regular true type characters.  Also, they don't appear when I look in the symbols either.  It gets to lowercase omega and then just shows a bunch of question marks.
Dan
Parents Reply Children
  • Hi Jonathan - we're seeing the symbols, so that's great!  Can you please confirm if this is so supposed to fix the key-in codes for the characters as well?  And if it is, can you please confirm the key-in strokes? For instance, I thought I should get a symbol if I type "F2004" (without the quotes) and then press the ALT and X keys at the same time.  That's how it's working in Office products.  Is this an incorrect workflow for ORD?
    However, regardless of whether the key-ins work, the symbols are now showing up, so that's a huge improvement - especially for a Friday afternoon.
    Thanks!
    Dan
