Is there any training support for the OHDOT Monument Report Generator available in the Ohio DOT workflow? When I attempt to place in survey master I receive a "could not find survey master excel file within the workset" error. The spreadsheet comes with the workset and also is selected in the report generator. Thanks.
Mark,
Under the Help menu there is a pdf optoin. that will open the documentation for this app. I have not gotten around to making the how to video yet. but when it initially loads it will see to set the survey master file if it can find it. if it doesnt find it then use the search button thats to the right of the survey master line at the top. that will let you select the survey mater file.
it should work after that. if not please let me know.
JD
FYI the app initially looks for a file in the 300-Survey\SurveyData\Reports\. if there is a file there with Surveymaster in the name and the file ext is.xlsm it will use that.
Thanks for the reply. As usual - nothing seems to work until I ask for help. All good now.
