Title Sheet Map
Is this feature unusable in it's current state or should it be generating something? I see the "coming soon" images in regards to the KMZ functionality but if I insert a PID in the that field I get something populating down below that then activates the Generate Map function but nothing actually generates. Just wondering if this is working for anyone of if you are inserting rasters?
Edit: So I was able to get it to generate a small map in .png form but attach image never populates? Also the app just crashes if I try to get an image above 450x450.
Chris
Parents Reply Children
