ORD 2021 R1 10.10.01.03
Is there a way to get the existing profile grade elevation to show up along with the proposed in cross section drawing models? The "Drawing Model Annotation" annotates the station and proposed profile grade elevation. I looked through the cross section sheets guide on the Wiki but didn't see this mentioned unless I'm mistaken.
Thanks!
Ben
In theory, you could try adding a point to your templates to seek ground at the CL, then have that be a specific feature definition also tied to a text favorite linked to an annotation group. Here's a post that describes well the hierarchy. https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/199375/ord-feature-definition-hierarchy You can also look into use of an annotation filter as mentioned in the following video. https://www.youtube.com/watch?v=cA-pu-DfcdI
Thanks for response, Shawn.
