I am working on a project that was created in SS10/V8i and currently at the 60 percent stage. Can I convert it to the CONNECTS/ORD workspace?
TxDOT recommends that projects beyond the Alignment stage remain in Geopak. However, if all you have created is an alignment then you can covert to ORD.
Resident Engineer
I have the model created and all the sheets have been created as well. I guess that means I stay with Geopak? The project is letting in 2027, so we have time between now and then and if I convert it now, I can take advantage of the new tools as projects go through numerous changes till it is finally lett.
