There is an issue with communities page loading speed from different local offices. Sometimes portal is almost unusable as it takes forever to load any page in communities.bentley.com while other sites work correctly.It appears that the main bottleneck is that some images are very slow to load using SSL.
For example when experiencing slowdowns this image(HTTPS) doesn't load at all:
While this image loads instantly(HTTP):
Hmmm... we have heard about this intermittently (and not consistently across all situations). We would be interested in getting more details so this can be investigated.
What kind of details are needed?
A Fiddler or Wireshark log would be good (but please do not post that in the forum... please send that to me offline).
ok, will prepare next time it occurs. Firebug net logs also would be good?
Yes, that too (sometimes more than one different kind of log helps narrow the possible causes).
