both when creating a new post or answering an existing one using Advanced text editor, the tabs are not displayed, so it's not possible to attach a file and to check the post in the preview.
[Edited] Using the latest Firefox on Windows 8.1 64bit, IE tested quickly with the same result.
With regards,
Jan
Yes... you can use Insert media to attach a file (this is a change in the platform). We will put something in the blog regarding this as I expect others to have the same inquiry.
Hi Phil,
thanks for your fast answer.
Unknown said:Yes... you can use Insert media to attach a file
Ok, it should work. I hope images will be not automatically downsized, sometimes it's useful to attach bigger image / screen capture and it's when the plain attachment was useful, because the original raw file was displayed.
And what about the preview? I have used it every time for last time check before a posting. My experience is I overlook sometimes typos in editor and found them in the preview mode.
Thanks for the excellent constructive feedback and for your (very valid!) points. We are bringing this up as something to consider (not likely for the next Communities platform release, but for one after that).
Mark Mates - BIM Manager - Mason & Hanger
I always used the preview to make sure my posts look correct, since the edit layout and the final post layout end up being somewhat different.
See screen capture below for example of differences when this post was being edited.
fresh experience with a situation where the lack of preview mode causing uncomfortable troubles: Inserting a code using Syntax highlighter.
This tool is awesome and it's a huge progress forward, thanks! ... But the problem is the code is displayed normally and not formated after inserted using the highlighter. So without the preview it cannot be checked anyhow if the result will be correct.
Example how a code looks in the editor and when posted ... huge difference:
