just out of curiosity...
what sort of posting frequency does a user need to hit to get the  'My Badges' stars highlited?
Not aiming to up my postings but am just curious.
  • The badge stars indicate the following "point tiers":
    1. One star (0 - 1000)
    2. Two stars (1001 - 7500)
    3. Three stars (7501 - 25000)
    4. Four stars (25001 - 50000)
    5. Five stars (50001 - 500000)
    The number of points is calculated by the following factors:
    • Post Factor: The amount each post is worth.
    • Reply Factor: The amount each reply is worth for the original post.
    • Replier Factor: The amount each unique replier is worth for the original post. Additional replies to the same post from the same replier are not included in calculation.
    • Verified Answer Factor: The amount a member receives for having a reply verified as the answer.
    • Rating Factor: The amount each rating is worth for the rated post.
    • Download Factor: The amount each download is worth for the original post.
    • Downloader Factor: The amount each unique downloader is worth for the original post. Additional downloads of the same post from the same downloader are not included in calculation.
    • Favorite Post Factor: The amount each post receives for being selected as a favorite.
    • Favorite User (Friend) Factor: The amount each user receives for being selected as a favorite/friend.
    • Rater Factor: The factor used to determine the value of each rating for the rater (points = Rating * Rater Factor).
    • Wiki Comments: The amount of points a user receives for adding a comment to a wiki article.
    • Wiki Edits: The amount of points a user receives for editing a page in the wiki.
    • New Page: The amount of points a user receives for publishing a new page to the wiki.
    Any activities that act upon a member's own posts are not credited with points. For example, a post does not receive points for a reply if the author replies to himself/herself; rates his/her own post; downloads his/her own file, or marks his/her post as a favorite.
    Although the factors involved might be subjective to some, the points and rankings do provide some insight as to how each Be Communities member's overall contributions and "reputation" compare to others on the site.
    Answer Verified By: dshaw
  • Hi Phil - shouldn't you have some stars? ;-)
    regards / Thomas Voghera
  • Thanks for that Phil,
    I verified your answer so there's a little extra point for you ;-)
    Not sure what you mean... like this?
  • I don't see any stars 1 cm above where I am typing now.
