I am unable to access communities some pages as the page stucks in endless loop. There are issues when opening http links while I am logged in bentley site using https. If I open links to communities from email notification which has http it doesn't work but if I replace it by https then page opens. Seems it doesn't correctly forward to https. examples: communities.bentley.com/.../99075 communities.bentley.com/.../99075
Also I see warning that browser has blocked parts of the page which are not delivered trough secure connection.
See the attached video how to reproduce this issue. It is not normal workflow as typically this happens if following links from email notification or from google results. It happens only for some pages.
Thanks for the positive feedback, Oto. I'm glad to hear that things are working better now.
Unfortunatley not entirely. If community page is left open then it logs from SSO out(lost connection error) and logging back on Bentley.com doesn't help. Cleared cookies again maybe it will help.
If the issue still persists after clearing cookies, I have contacted you directly via a service request to obtain further diagnostic information for troubleshooting.
test
test, still good but again I am kicked out from connect.bentley.com and have to log back in there but not in communities
