Unread/Read weights are too similar
When viewing a forum the visual distinction between Unread and Read posts is negligible. It would be nice if there was a greater difference in the weights used for the subject of the posts.
For example:
Read Posts - currently use weight of 500
Unread Posts - currently use weight of 600
Read Posts - I propose reduced weight of 300
As shown above, reducing the weight of read posts to 300 would not take up anymore space, and it would make the Unread posts stand out better.
Ron
Parents Reply Children
