I have not been replying to posts for awhile now. Today I was trying to reply to some posts using Chrome Browser. When I click on reply my avatar is displayed but there is no dialog box to type in. I've been using IE today so I am able to post topics & reply to posts. What's up with that? Anyone else seeing this problem?
Chrome Version 60.0.3112.78 (Official Build) (64-bit)
Windows 10 Enterprise version 1703 OS Build 15063.483
Hello mwlong,
From your description, it sounds like you may have encountered the problem shown in item #1 of the known issues sticky post on the top of this forum. Please try pressing CTRL+F5 to refresh browser cache and let us know if that works. Apologies for the inconvenience.
I received your private message stating that you have tried CTRL+F5 but the problem persists. Are you certain that the control key is pressed while pressing F5? Some laptop keyboards have a function lock that might need to be toggled. I also assume that you are signed in. If this does not help, can you provide a screenshot showing the issue?
Well, I am on a PC not a laptop. From my home PC now I had to reinstall Chrome as it was causing some problems. Now I can reply to this post. I will need to try to post from my work pc and see if it works there tomorrow. I may need to reinstall there also.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Uninstalling & reinstalling Google Chrome fixes the problem.
Glad to hear the problem is resolved. The reinstall likely also refreshes browser cache.
