I just posted a new question and it seems my signature (which mentiones the version we use) didn't show anymore. I added it manually.
It showed up in the past, not sure if this is related tot the updated fora?
Hi Stefan - I've checked your account and your signature is still extant. Can you post back here if it happens again?Thanks,
Duncan Brown
(My sig showed up!)
test
Windows 10 pro
OpenBuildings Designer Connect Edition 2023 | 23.00.00.114
ok seems to work now :-)
