The private message switches to different person before I can get my message typed.
There seems to be a problem with the private message system. I was trying to send a message to a new person and about 3 words into my message it switches to someone I have messaged before. I ended up having to type my message into notepad and then copy and paste it over and hit enter real fast so it would send before it switched away from the person I wanted to send it to.
  • Hello Ryan,
    I'm sorry to hear you're having difficulty with private messages. I have not heard of this issue before. Are you able to reproduce this consistently? (certain member or any members?) Could you provide any additional details? For example how did you initiative the private message - by continuing an existing conversation (clicked from the left side of the PM window?), by searching for and selecting the number first, or something else?
    When it switches, do you mean that the member name shown at the top suddenly changes to someone else, or that it switches to a different conversation (on the left side).
    I experimented a bit with this and could not reproduce.
    Jesse Dringoli
    Bentley Systems, Inc.
  • It was consistently doing it yesterday when was trying to send a message. Today when testing the issue with your name, it did the same the first 2 or 3 times and I noticed that it appears to be related to the message in the upper right corner of the forum window that says "successfully reconnected". When that flashes up it switches from the message I'm trying to type to the first name in my list of past messages.
    What I had done was go to the person's profile that I wanted to send a message to and click the Connect>Send a Private Message. The private message window would come up as expected and as I was typing it would flash and it would switch to the first person in my previously sent list.
    After having it failing a couple of times this morning it is currently not having the issue. I'm not sure what was causing my loss of connection to the forum. However, it seems that even if there is a momentary loss of connection it should keep what I was working on and not switch to a different message.
  • Ok, thanks for the details, Ryan. I will look into this.
    Jesse Dringoli
  • Hi Ryan, I tried to reproduce this issue without success. As you said, it might be related to your loss of connection while trying to send the message. Are you still experiencing the issue with the loss of connection and thus the PM issue? (are you seeing the "successfully reconnected" orange popup?
    Jesse Dringoli
  • Yes still having issues this morning with it. I don't know why I keep seeing the Successfully reconnected message. My internet seems to be working fine here right now. Here's a video of what is happening.
