I have four notifications unread, but when I check them this is whay I see:
This isn't the first time I see this happen. Is there some settings that controls this or anything?
Thanks and regards
Hi Jose,
Yes this "phantom unread notifications" issue has occurred before. We will look into manually clearing these out for you and will try again to investigate why this happens. I suspect it is related to content that was subsequently deleted or marked as hidden but I am not certain. Apologies for the confusion.
Your "phantom" unread notifications should be fixed now. You should still see four notifications, which you can review and clear at your leisure.
Answer Verified By: Jose Pinho
