It appears that the ability to comment on blogs has been stopped. Is there a reason for this?
As an example see https://communities.bentley.com/products/microstation/b/microstation_blog/posts/the-explorer-part-three-the-items-tab which doesn't have the comment section at the bottom!
If you see a case where a technical question on a Forum does not get a timely answer, please let me know and I will look into it.
Jesse Dringoli said:If you see a case where a technical question on a Forum does not get a timely answer, please let me know and I will look into it
Try this one. https://communities.bentley.com/products/microstation/f/microstation-forum/174705/like-v8i-you-ll-love-connect---make-using-bing-maps-a-snap-by-using-microstation-connect-edition I kmnow it's only been one day but even so the OP must be able to answer the question.
Hi Stuart, I will find someone to answer the question for you. Thanks for bringing this to our attention.
Another one un-responded https://communities.bentley.com/products/microstation/f/microstation-forum/175157/like-v8i-you-ll-love-connect---recommended-scales
Hello Stuartw, I have sent a message to Shaylesh to see if he can help here.
